After neglecting my laser for the better part of half a year,
After neglecting my laser for the better part of half a year, I’ve been welcomed back with a repeat cut issue. My laser is repeating the cut, even though I have have not specified a repeat. From a previous post https://plus.google.com/111366654976766633425/posts/dLjxuWbVMTq I think it may be due to my drawing not having a “solid infill” therefore the laser is cutting on either side of my line… I’m confused as to if this is a CorelDRAW setting or is my .dxf file that is the problem?
Try 0.01mm line width. Usually fixes the issue. Also, I’ve seen when some people have the Cutting Data set to a funny option (in the CorelLaser plugin settings) that it ends up causing some odd things (double line being one of them).
See: https://drive.google.com/file/d/0Bzi2h1k_udXwWVlDR3RyTzlzemM/view?usp=sharing
@Yuusuf_Sallahuddin_Y My settings we nothing like the sample but updating them didn’t solve the issue. Changing the line to 0.01mm did the trick though. Thanks a lot!
@Linda_Barbakos You’re welcome Linda. Glad to have helped.
