After a multi-months of little to no time to work on my HercuLien,
After a multi-months of little to no time to work on my HercuLien, I am back in the workshop. Of course, I have a couple of questions:
  1. If you ordered the Ali Rubber 120v heat bed, does anyone know the thermistor type they use, so I can set it up properly in my Smoothie Board config?
  2. Same question for my E3D Volcano, what setting do I use; I did not see the model for the one they sent, I looked all around e3d site, but maybe I missed it.
The rubber heater should be NTC100 about 100k ohm.
  1. The beta value for Alirubber seems to be 3950 (see here https://plus.google.com/+OliverSeiler/posts/efA1VPMvRmX ) or check out Erik’s thermistortables.h
  2. The doc at refers to using ‘Semitec’
    http://wiki.e3d-online.com/wiki/E3D-v6_Assembly#Smoothieware
Doc at Smoothieware:
http://smoothieware.org/temperaturecontrol#toc5
So in your config you would have
temperature_control.hotend.thermistor Semitec
and
temperature_control.bed.beta 3950
I’m sure someone here has found more accurate ways (@Eclsnowman maybe), but it works fine for me :wink:
@Oliver_Seiler yes, I confirmed on the alirubber bed via a thermocouple the beta value of 3950 is accurate within 1deg C. Good enough for me.
Awesome, thanks for the quick information on both, and the links, I missed that on the E3D wiki!
@Bruce_Lunde , I used the data sheet for the thermistor and fit it to the Steinhart-Hart equation. This should give you the most accurate values over the entire operating range: https://plus.google.com/115824832953735584348/posts/Tr9kzbSucjR
But because it’s only the bed, stability is more important than truly accurate temps
It’s #11 in Marlin, I believe.
For the bed thermistor from Alirubber, I found I needed to add a configuration of R0 to be a bit less than 3000. R0 is the resistance of the thermistor at 25C. You can measure that with a multimeter if you want.
Thanks all, I have updated my setting, now I just have to wait for an extruder gear and some screws to finish up (how is it that parts just disappear from the workbench,) . Lucky for me Filastruder and Trimcraft have already packaged for shipment, so with luck (and USPS) , I may be finalizing the build this weekend.
Hi
I know many orders from alirubber and Thats probably good
I ordered My from robotdig, i thought that might be interesting for you to look at as well
This is the one i ordered
Silicone Rubber Heater Pad
300*300mm, 12V or 24V 300W
