After a long hiatus I cleared off the top of my CRP-4848 and decided I wanted to work on some projects.
I discovered that the high voltage power supply for the steppers would fail when three or more steppers were in motion. Tracked it down to a failing power supply and replaced it. Although, not before falsely diagnosing one of the Gecko 201x drivers as the culprit and buying one. Oh well, got a spare now.
Next up a dust shoe, new remote pendent, and a touch screen.
I just posted on my new pendant. Easy to make and install.
I’m using Mach3 with the Calypso Ventures MachStdMill screen set, which I really like. I will eventually switch to Mach4 after I write or get a screen set that matches MachStdMill’s feature set.
@Jay_Polo Close, the base board is a good piece of 3/4 inch birch plywood. On top of that is a half inch of MDF. The idea is to replace the MDF as needed. The t-slots were milled with the table. They work pretty well. Only annoyance I have is dropping things between the slots. It can be a challenge to fish things out if they are not magnetic.
