So much thanks to you and Sam and everyone else in this community. With prices falling on WS2812b strips (getting pretty close to $0.05/pixel with some hunting on aliexpress) and the introduction of MCUs like the ESP32 with tons of memory and serious processors in an $8 package, the limits of what a hobbyist like me can dream of have literally expanded by an order of magnitude in basically one short year. Its been an exciting time!
Tommy, this is perfect. I have an ESP32 BLE project using App Inventor already but used another LED lib and was about to try integrating fastLED. Thank you for this. This ESP32 is just getting better every day with help from people like you. I cannot wait to see what I can do with this. The App Inventor folks suggested we might start a separate ESP32/App Inventor section. It seems to be taking off as people realize how little it costs and how much it can do.
Well, it works ok but the lag is bad. I had to put a hook into my other LED lib where the tight loops were but that way I could use a slider to control some motors as I change the led patterns. I’d really like to make an App that lets the user program their own patterns using a more intuitive interface. No user interface lag is needed if there are ways to check and set a few globals as the lops run.
This is a paper clip mounted to a motor. The rotation rate and LED refresh rate make interesting moire patterns but fastLED seems to be much better than the simple version I have now. I am glad others are also interested in getting fastLED, esp32 and App Inventor working so it’s easy to have fun creating, recording and playing back various pattern combinations. missing/deleted image from Google+
BTW, I have a color picker app for named colors that I want to check against the fastLED colors. I posted it to the App Inventor group with little interest. The list of named colors allows designers to select “Android Green” and other official colors and can be used as a color swatch to match real world stuff. Named colors has a very rich history but I only have the 800+ that was in Wiki. I like how you set the background color. I did the same thing for the list of colors.
You might want to add the “StringSplitter.h” dependency to your github. I installed the lib but it’s always nice to know which ones are connected so when something breaks… Thanks again.
@Steve_Anken Just a heads up, you can only send 20 bytes on BLE through app inventor, so if you wanted to send a string of what patterns you wanted to the App, or a serial monitor, it has to be at max 20 bytes or else it gets cut off
@Tommy_Sciano , well aware of this. I send codes to switch patterns on the esp32, it does all the work. I can even send back notify for other stuff I am doing. The motor speeds are a few bytes. You can also split messages to get longer strings, someone posted code for that, but I don’t need them. My app really works nice as is but I need better color control like HLS to even come close to matching RGB screen colors on the Android. There some nice stuff in your code I will steal. Thanks and I hope we can get to the point where there is not so much duplication of this. I see a number of ESP32 BLE App inventor projects all seemingly doing the same basic thing.
@Jeremy_Spencer It’s something in the static library tools/sdk/lib/libspiffs.a.
I replaced it with the one from 70d0d4648766cea047613062ed50a9ecfc9de31f and everything worked again.
I use the latest version and then just went to an older branch to copy the library and it worked for me too
