Added some metric tape measures to aid in setting up materials...
Added some metric tape measures to aid in setting up materials… thanks for the idea @Ariel_Yahni_UniKpty
http://amzn.to/2b4413G This one Metric / Imperial was found by @funinthefalls
I have several more metric tapes if people are needing them
Are you still using the stock bed Alex? The metric tape idea is a good one. If anyone is wanting them in their local region you can usually find them at a sewing supplier (about 1m long).
This one is metal with an adhesive back… and yes I do use stock bed… I take it in and out depending on what I’m cutting
It had the perfect focal length for the material I was running… but upgrading to air assist has me reconsidering changing it out
@Alex_Krause Ah, metal tape sounds better than the sewing ones. Would just cut straight through them if you hit them haha.
@Yuusuf_Sallahuddin_Y ​ check Hangouts I sent you a message
