@Adafruit_Industries has started shipping #BeagleBoneBlack
Originally shared by Adafruit Industries
NEW PRODUCT – BeagleBone Black
The wait is over, we have them in stock and shipping
https://www.adafruit.com/products/1278/
We have them here and these ship immediately while they are in stock. If you liked the BeagleBone, you will love the next gen BeagleBone Black! With a blistering 1GHz processor, 512MB onboard DDR3 RAM, built in 2GB storage with pre-installed Linux operating system (no microSD card required!), and best of all, the addition of a MicroHDMI connector for audio/video output. This is a ultra-powered embedded computer that can fit in a mint tin.
Comes with a mini B cable for powering it up ASAP. No microSD card is included as the BBB now has onboard flash storage.
We’ll be filling in with more information on supported accessories as we test them for compatibility. For now we suggest picking up a 5V 2A power supply and a micro-HDMI cable. If you want to use it ‘head-less’, a USB console cable is suggested as the ‘Black does not have an onboard USB-to-Serial converter like the original BeagleBone.
Processor: Sitara AM3359AZCZ100 1GHz, 2000 MIPS
Graphics Engine: SGX530 3D, 20M Polygons/S
SDRAM Memory: 512MB DDR3L 606MHZ
Onboard Flash: 2GB, 8bit Embedded MMC
PMIC: TPS65217C PMIC regulator and one additional LDO.
Debug Support: Optional Onboard 20-pin CTI JTAG, Serial Header
Power Source: miniUSB USB or DC Jack, 5VDC External Via Expansion Header
PCB 3.4” x 2.1” 6 layers
Indicators 1-Power, 2-Ethernet, 4-User Controllable LEDs
HiSpeed USB 2.0 Client Port: Access to USB0, Client mode via miniUSB
HiSpeed USB 2.0 Host Port Access to USB1, Type A Socket, 500mA LS/FS/HS
Serial Port UART0 access via 6 pin 3.3V TTL Header. Header is populated
Ethernet 10/100, RJ45
SD/MMC Connector microSD , 3.3V
User Input: Reset Button, Boot Button, Power Button
Video Out: 16b HDMI, 1280×1024 (MAX), 1024×768,1280×720,1440×900
w/EDID Support
Audio Via HDMI Interface, Stereo
Expansion Connectors:
Power 5V, 3.3V , VDD_ADC(1.8V)
3.3V I/O on all signals
McASP0, SPI1, I2C, GPIO(65), LCD, GPMC, MMC1, MMC2, 7
AIN(1.8V MAX), 4 Timers, 3 Serial Ports, CAN0,
EHRPWM(0,2),XDMA Interrupt, Power button, Expansion Board ID
(Up to 4 can be stacked)
Weight 1.4 oz (39.68 grams)
In stock and shipping now!
#beaglebone #beagleboneblack @BeagleBoard.org
