ABS or PLA?  This is the printer that matters.
ABS or PLA?
This is the printer that matters. I’m taking everything learned in the 3DR build and applying it here. Heated build plate, auto leveling, hiding the power supply and guts, potential for multiple extrusion…
So, considering it’ll have a heated build plate, and potentially side covers to cut down on drafts would seem to point towards ABS…however, I’m using an e3d, which keeps pretty darned cool, and the build plate will have an airgap and a buncha aluminum between the heat and the plastic parts.
Does it need to be ABS, or would PLA suffice?
The E3D keeps cool by shedding the heat efficently. Combine that and a heated bed inside even a semi-enclosed space and it’s going to heat up quickly.
Personally, if “This is the printer that matters,” I wouldn’t be using the word “suffice”. Go with the ABS (heck, even Nylon!).
Yeah, I’ll be going ABS. I’ll print nylon parts on my own time with it, if it comes to that, which I doubt.
Does the flexibility of nylon have a negative effect? I’ve only printed thin nylon parts so not sure how rigid it is / good for printer components (vs abs which is prone to contraction / warping issues)
Nylon vs abs, which one?
Don’t print Nylon for structural parts, for the same reason you wouldn’t do them in PLA. Nylon has a very low (lower than PLA) heat deflection temp.
