About the Quadrap category
(Michael K Johnson) #1
(Replace this first paragraph with a brief description of your new category. This guidance will appear in the category selection area, so try to keep it below 200 characters.)
Use the following paragraphs for a longer description, or to establish category guidelines or rules:
  • Why should people use this category? What is it for?
  • How exactly is this different than the other categories we already have?
  • What should topics in this category generally contain?
  • Do we need this category? Can we merge with another category, or subcategory?
(anon57870006) #2
QuadRap started at GitHub with a strap version that did not include any printed parts: only cut and drill aluminum consumer profiles.
Its first main characteristic is the corner connection that is low cost but very rigid and self aligned.
Second is using twin steppers for each of X and Y what allows very long spans without heavy and expensive shafts.
Third is that it run all on wheels - sliding and linear bearings are avoided but allowed.
It has proven to be much easy to build than other Cartesians delivering stunning quality of prints.
