A vacuum pump with DC motor
This project shows how to control a cheap DC motor pump. It’s the follow on of my previous project reusing a fridge compressor.
Electronic board to automate the vacuum pump
This board has the following characteristics:
  • An ESP32 microcontroller will handle all the logic and communication with smartphone over Bluetooth Low Energy and WIFI over UDP
  • two 5V relay boards can handle a 230V AC fridge motor coils (compatibilty with fridge compressor)
  • an OLED display could be used for debugging
  • a pressure sensor will convert vacuum level into a voltage read by the ADC of the MCU
  • a DC motor can be controlled via N channels Mosfets
  • a brushless DC motor can be controlled with an ESC controller (optionnal 5V control stage)
  • The board is powered (optionnaly) with a cheap 12V to 5V DC/DC converter
So this board should be more versatile than the previous one!
A devoted Hackaday’s project has been created. Please follow this project for more details : DC motor Vacuum pump @Hackaday
It demonstrates how to control this 12V DC motor pump :
VC-N1
Everything is open source open hardware.
It’s a diaphragm pump which is very noisy. I have found a way to decrease noise. Quite efficient !
