A question about autoleveling and g92 command.
@Whosa_whatsis
Due to my probe arrangement ( and it happens with every other printers probe arrangement) i am having an issue using non grid auto levelling. for defining 3 points (which are at extreme points of my bed) the co-ordinate are inserted manually and someone of which are going in negative as i have to give probe co-ordinate and not nozzle. This info is not relevent to my issue. but i needed to tell it as you can see why i have this issue.
Say i ran g29 and then change the co-ordinate with g92 X0 Y0.
then does the autoleveling matrix shift accordingly ( i presume it will require a change in z only) or it will remain intact.
Imagine at my previous (0,0) my dynamic z co-ordinate assighned by autoleveling is “x” , now if i move my origin to another point then will it be “x” again or new x is considered which was actual correct z before g92
I needed to do this to get co-odinates fir my beds as by probe points are outside of its and to reach those i have to use larger then normal co-ordinates in firmware.
I hope my question is clear.if not please ask so.
Thanks in advance.
