A little more and the Thing should print. I am waiting for aluminum carriages X and Y and I will mount limit switches. There remains little solder and launch full functionality Of course, expect small issues, as always, but at this stage everything is ok
https://youtu.be/tpiSKXwYud4
Awesome! What hot ends are you going for? I want it in alu now:)
For now I designed a X carriage for 2x E3D v5 hot end. The aluminum housing is robust enough and stiff
Great! I would go for a V6 if you have not got two V5s lying around, and also E3D Titan as extruder in case you donβt want to make that for yourself as well!
Fortunately for the moment I have one piece of v5, so I can later test v6. I would like to make an inductive sensor but not all at once - the current target is the first effective print Tomorrow I need to make new mounting for table from thicker angle - now the front of the table falls under its own weight.
