* A HEADS-UP TO UK COMMUNITY MEMBERS * Please do not let Eaglemoss fool
Please do not let Eaglemoss fool you or any of your friends into building this printer in 90 instalments at £6.99 a pop. It will be a 2-years out of date design when you finish, it will cost £630, it will not work, Eaglemoss support will be crap and it will all end up on watchdog.
I’ve not seen the printer design before, expect it will be as bad as a lot of the kickstarter printers. Their touted designer has never done a printer before, he’s just an expert at “brand”.
For previous Eaglemoss cons, look at the Spitfire R/C model, because a balsa spit is the right model for a total amateur without even BMFA insurance. Also the Subaru Impreza R/C Car with 3 Speed mechanical controller that would wheelspin out of control at speed 1. Both these ended up on Watchdog.
http://www.eaglemoss.com/en-gb/technology/3d-create-print/
If anyone wanted this printer pre-built . It’s just an Alfinia Up plus in a box.
