A few days ago, I made a post about an articulated cyborg penguin I had made for Snolabs. He will put your printer through its paces, as he has the following points of articulation:
Turning head
Moving wings
Legs that can twist and fold
Moving tail
There are 2 versions a 100mm and 80mm. The difference is some tweaking of tolerances to allow for scaling and not risk welded joints:-)
I found the following worked well:
.2 layer height
3 perimeters (this is very important, especially for the smaller guy)
15% infill
60mm/s but I am a printing slow coach…
Available in all the usual places but I shall link to Cults here:
@Eclsnowman Ha! He’s fantastic. If you have time once you print the other one, maybe you could take a picture of them both glowing together. So happy your boys enjoy him.
So I just spoke to Norman from Snolabs and he says if you post your makes to Twitter and use the tag #SnoLabd3D then you can get 10% off a roll of their filament. It’s very nice indeed.
