7" Kuman screen. change the default rotation to 180. plug and play… I can move the box around and rotate it. upper right control and upper left temp view is un tappable …
Toggle concept is great but now I think its only for monitoring temperatures. Rest is useless for me. Better solution is Printoid on some 7 inch or bigger tablet. It has a lot of Octoprint features to use printer without PC.
Was this plug and play? Or did you have to perform a config file exorcism…
I want to put a screen on, this might be a good placeholder for the manga rev2, but depending on the complexity I might wait…
Sort of…
I had to rotate the screen in local config of toggle
It probably is my setting but both manga screen and this one isn’t responding to button presses for now…
