Looks like a wider range than I have on mine. I don’t hit 4ma (where it begins to lase) until your 60% mark and then it’s at 20ma about where your 110% would be so couldn’t just rotate it to start 0 further clockwise. It doesn’t look like the machines have the same linear power scale.
I don’t think so. I expect it’s just different pots. Yours is likely a wider range than mine. I wouldn’t expect all the mfg use the same value pots for their power controls. Mine still runs thru the whole range of 0-24ish milliamps.
I have even less range than all have stated lol I have a feeling it has to do alot with the internal trim pots of the power supplies due to over driving the tubes
