3D printing wood experiments: iPhone case and patented in 1920 hand prosthesis.
Is this using that Laywood material?
Yes. The nice thing is that I just use my PLA profiles and it works like a charm
Which supplier did you purchase the filament from?
Ok, thanks!
Can it be sanded more easily than PLA?
@Sean_Bires_Renzu compared to normal PLA it seems to handle sanding a lot better. The material is like wood but not really wood because its flexible also
Does anyone know a US supplier for Laywood?
yoink
Be prepared to have your wallet cry out in pain. It’s $132/kg vs. $38/kg for regular PLA filament
I just saw it. Thanks for the link…
bummer they are currently out of stock on 1.75mm laywood:(
Cool! Is that iPhone case the one I customized? The parameters are the same at least http://www.thingiverse.com/thing:40768
I actually thought that next to the iPone case I could see a V-brake of a bicycle…
The Iphone case would look great in Aluminum.
