I made a barbed adapter and some pipe bend savers I thought I’d share :
Cool.
Alot of us have also added a flow switch that shuts down the lps when there is a flow fault.
Great - do you have any recommendations ?
Here is one that is used frequently and has a lot of documentation on the web available.
YF-S201 Flowswitch
Here is an example that I came up with;
My setup is here…https://donsthings.blogspot.com/search/label/K40%20Cooling
I use a LO flow switch but I see it is currently not available on amazon. Often they go out of stock and then reappear.
It’s here though: https://www.lightobject.com/Water-Tubing-sensor/Water-flow-pressure-sensor-Ideal-for-CO2-laser-water-protection
Great - thanks - I’ll look into something like that too.
