Looking for a 4th alternative to the three options listed on the BOM for the small pancake steppers.
The aliexpress without gear is discontinued, would rather not grind off the gear on the other.
And just got my order from moons for the $25 dollar motor and they shipped me the wrong one.
Thought maybe I would try stepperonline, found this motor:
My worry with the 0.9 degree is that it will have way less torque because the coils inside the motor can’t be as big, thus you can’t drive as much current through it, but not totally sure.
You could also try a Nema 14, but since they are thicker, you’d have to redesign the shell to be longer, which isn’t super easy/fun in Fusion 360, but it runs at 1.2A so it’s way stronger than the pancake motors that run at 150mA. https://www.aliexpress.com/item/4000110145154.html
I have found that using a Dremel with a little grinder disc isn’t too bad to cut those gears off the stepper motor shafts.
