330mm tall at .1mm layers took 27 hours to print on my RostockMAX. New filament from Winbo seems to work just fine if a little on the hot side. New Slic3r pillar supports worked like a charm once again!
Beautiful!
That is amazing-looking.
Awesome Milo Venus print… I have just the torso printed because of the lenght of printing and support… Kudos…
I would like to draw organic shapes like these but I can’t do it on autodesk inventor, any suggestions for suitable software?
Try scanning with David Scanner…
Ah, I suppose I could sculpt a shape out of foam and scan it. Thanks for the idea.
That’s great quality printing. Well done.
That’s sweet!
Can you share stl file?
Thank you!!
Which hotend you are using ?
Stock seemecnc that came with the kit
