Made with Filemaker Pro.
This is setup by a Glowforge user so you will see that as the basis for this database. It can be modified for your own needs.
From the creator
I created a 3 in 1 database that makes keeping track of Projects, Resources and Materials a lot easier.
TheProject part consists of:
Project Name, Date,Completion Time, Source, Tags, Location, Setting Notes
And WEB Addresses for Project,Maker,Video and Instructions.
Up to 9 settings can be made for Materials, Function, Speed, Power, Passes and LPI .
The Resource part consists of
Resource Name, WEB Address and Resource Type
The Materials part consists of
Material Name, Size, Count, Cost, Source, Location. Date and WEB Address
I populated the Resource section with 155 useful for laser cutting resources
that I have collected over the years…
There is also a small Users Guide (LaserCut.pdf) in the LaserCut folder.
You should be able to download the LaserCut-MAC and LaserCut-PC apps
From the Dropbox links below.
To run the database, Unzip and run the LaserCut app in the LaserCut folder.
(The PC version works great. The MAC version may have a problem finding
the LaserCut file. If it does, try double clicking on the LaserCut.fmp12 file.)
