16 Port Parallel Output on Teensy 3.0 Missing Red Channel
Hi, I’ve been sucked into work for a while, but I’m now feverishly working on getting my art car ready for the burn.
I’ve been playing with designing and milling boards (with an Othermill which I’m in love with).
Anyway, to make a long story short, I’ve been having a lot of trouble with the FastLed 3.1, Teensy 3.0 (and 3.1) and the Parallel Output stuff.
I’ve designed a board that takes two 74HCT245’s so that I can use the PortDC stuff. When I use the Teensy 3.0’s I’m somehow not getting any red output. I’m basically using the ParallelOutput demo (shortened for clarity)…
There’s a lot of stuff going on in my signal path (Teensy 3.0 → 74HCT245 → 100Ohm Resistor → Ethernet Cable → Ethernet Splitter → 100Ohm Resistor → WS2812, but since the problem is just with the red leds I’m assuming that something is going wrong on the software side…
Any clues? [Arduino 1.6.4, latest 3.1 branch, Teensy 3.0]
#include<FastLED.h>
#define NUM_LEDS_PER_STRIP 20
#define NUM_STRIPS 16
// Note: this can be 12 if you’re using a teensy 3 and don’t mind soldering the pads on the back
CRGB leds[NUM_STRIPS * NUM_LEDS_PER_STRIP];
void setup() {
LEDS.addLeds<WS2811_PORTDC,16>(leds, NUM_LEDS_PER_STRIP);
LEDS.setBrightness(255);
void loop() {
static uint8_t hue = 0;
for(int i = 0; i < NUM_STRIPS; i++) {
for(int j = 0; j < NUM_LEDS_PER_STRIP; j++) {
leds[(iNUM_LEDS_PER_STRIP) + j] = CHSV((32i) + hue+j,192,255);
// Set the first n leds on each strip to show which strip it is
for(int j = 0; j <= i; j++) {
leds[(i*NUM_LEDS_PER_STRIP) + j] = CRGB(255,0,0);
hue++;
LEDS.show();
LEDS.delay(10);
