I just finished printing these two robot-style figures and wanted to share my results.
I really enjoyed the process of combining cute character designs with mechanical details. However, I noticed that some small areas (especially the eyes, face details, and tiny mechanical parts) are still challenging to get perfectly clean.
My print settings:
Material: PLA
Layer height: 0.2mm
Nozzle: 0.4mm
Infill: 15%
Supports: Yes
The overall quality is good, but I’m curious about how everyone optimizes settings for detailed character prints.
Do you usually reduce layer height to 0.12mm for this type of model, or do you adjust things like wall count, speed, cooling, or temperature first?
Would love to hear your experience and suggestions!
In Prusa Slicer (and derivatives) you can select the ‘adaptive layers’ tool and apply it to the parts. This will reduce layer heights as needed in areas with high detail and overhangs etc. while using thicker layers where it is unimportant.
It’s much faster than having to print the whole model at a small layer height dictated by the smallest detail.
If you are able to print in ABS then you can do the final smoothing of the exterior with a 10-20 second dip in the fumes of warmed acetone(many videos about the process and safety). The results can be a smooth shiny surface with little to no signs of layers.
That is a great example of where the tradeoff between detail and print time becomes noticeable. Adaptive layers sound especially useful here because they preserve faster 0.2mm layers on broad surfaces while refining the face and small mechanical features. I would also compare cooling and outer-wall speed before committing the whole model to 0.12mm. Have you tried adaptive layers on these figures yet, and if so, did the transition areas print cleanly?
Thanks for the tip! I’m currently using OrcaSlicer. I’ve actually been meaning to try adaptive layers, so I’ll definitely give it a shot. Being able to use smaller layer heights only where the details need it sounds like a great way to improve the print without making the whole print take forever.
Hi Ryan,
You’ve received excellent advice above; I just wanted to directly answer your question.
0.2mm vs 0.12mm layer height for character models
Yes, it matters. The way I think of it is (assuming a 0.4mm nozzle):
At 0.3mm, you can see the layer lines.
At 0.2mm, the layer lines are less pronounced. I believe this is why most printers/ slicers in their profiles these days treat 0.2mm as standard, and rarely offer 0.25mm or 0.3mm layer heights, and if they do, it’s only as “draft” quality. 0.2mm truly is the happy medium of print speed vs quality.
That said, for something as precise as models, I would consider it not ideal enough, and I would absolutely spend the extra time going down to 0.15, 0.1, or even 0.07mm layers if absolutely fine detail is needed.
As suggested above, you can use the variable layers feature to help you adjust dynamically based on the slope of the overhang.
0.2 to 0.1 is the range you want to be in. I might want to use 0.15mm as my overall height, but it depends on how tiny vs huge the model is.
Thanks for the detailed explanation! That makes a lot of sense. I think I’ll try 0.15mm as a starting point and use variable layer height for the areas with finer details or steeper slopes.
I also like the idea of balancing print time and surface quality rather than just using the lowest layer height everywhere. I’ll definitely give 0.1mm a try on my next detailed model and compare the results. Really appreciate the advice!
Thanks! That looks like a great choice. I’ll definitely give it a shot, especially since I’m almost out of filament. Really appreciate the recommendation!
I’m not sure if anyone else has mentioned it, but variable layer height can sometimes cause banding.
Some filament are sensitive to the speed that you lay them down. some come out matt or glossy at certain speeds so changing the speed changes the finish and can cause banding.
It’s not strictly the actual speed that causes this, but the factors involved tend to be associated with speed changes.
That’s a really good point. I think variable layer height is often recommended for improving details, but people sometimes forget that consistency of the surface finish can also be affected.
Especially with certain PLA filaments, the change in gloss level can make layer transitions much more visible even when the actual layer height difference is small.
It’s interesting because it shows that print quality is not just about resolution — things like material behavior, cooling, speed changes, and extrusion consistency all play a role.
Have you noticed this effect more with specific filaments or colors? I’ve heard silk PLA and darker colors tend to show these changes more easily.
It’s not very noticeable to me, although I mainly print glossy black PLA. But I don’t use volumetric printing, so layer speeds remain the same for me, only the thickness varies.
I do see visual effects of the layer lines varying, it can make some parts of the print ugly. But I’m only really making functional parts, so this is less concern to me.
For figures, miniatures etc.. resin printers seem the way to go, even cheap resin systems outperform any FDM system on details.
